对于一个永磁铁的三维分析,分别采用标量法和棱边法计算,但差别很大,请问到底是什么原因?是因为电磁场的理论,还是我的命令流有错误,请大家讨论一下。
模型简介:
永磁铁:0.1mX0.1mX0.1m,剩磁1.12T,矫顽力780000,计算得到的相对磁导率为1.143
空气范围10mX10mX10m,相对磁导率为1
标量法:永磁铁和空气采用solid96,无限边界采用infin47
棱边法:永磁铁和空气采用solid117,无限边界采用infin47
提取坐标(3,3,3)的磁感应强度:
标量法:Bx=0.49831E-06
By=0.27287E-06
Bz=0.49831E-06
棱边法:Bx=0.54270E-06
By=-0.59086E-06
Bz= 0.54270E-06
!****棱边法****
/prep7
emunit,mks
!空气边界
b1=10
!磁铁尺寸
b0=0.1
!1个磁铁
!三维分析
!设置单元属性
!磁铁和空气
!低频棱边单元
et,1,solid117
keyopt,1,1,5
!远场边界
et,2,infin47
!设置材料属性
!空气
mp,murx,1,1.0
!永磁铁
mp,murx,2,1.143
mp,mgxx,2,0
mp,mgyy,2,780000
mp,mgzz,2,0
!建立几何模型
block,-b1/2,b1/2,-b1/2,b1/2,-b1/2,b1/2
wpoffs,,,-b0/2
vsbw,all,
wpcsys,-1
wpoffs,,,b0/2
vsbw,all,
wpcsys,-1
wpoffs,-b0/2
wprota,,,90
vsbw,all,
wpcsys,-1
wpoffs,b0/2
wprota,,,90
vsbw,all,
wpcsys,-1
wpoffs,,-b0/2
wprota,,90
vsbw,all,
wpcsys,-1
wpoffs,,b0/2
wprota,,90
vsbw,all,
wpcsys,-1
!建立有限元模型
!磁铁
csys,0
allsel
vsel,s,loc,x,-b0/2,b0/2
vsel,r,loc,y,-b0/2,b0/2
vsel,r,loc,z,-b0/2,b0/2
aslv,r
lslar,r
lesize,all,,,4
type,1
mat,2
vmesh,all
!6个小条空气
allsel
vsel,r,loc,y,b0/2,b1/2
aslv,r
lslar,r
lsel,r,loc,y,b0/2+0.01,b1/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,y,b1/2-0.01,b1/2+0.01
lesize,all,,,4
allsel
aslv,r
lslar,r
lsel,r,loc,y,b0/2-0.01,b0/2+0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
vsel,r,loc,y,-b1/2,-b0/2,
aslv,r
lslar,r
lsel,r,loc,y,-b1/2+0.01,-b0/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,y,-b1/2+0.01,-b1/2-0.01
lesize,all,,,4
allsel
aslv,r
lslar,r
lsel,r,loc,y,-b0/2-0.01,-b0/2+0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
vsel,r,loc,z,-b1/2,-b0/2,
aslv,r
lslar,r
lsel,r,loc,z,-b1/2+0.01,-b0/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,z,-b1/2+0.01,-b1/2-0.01
lesize,all,,,4
allsel
aslv,r
lslar,r
lsel,r,loc,z,-b0/2-0.01,-b0/2+0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
vsel,r,loc,z,b0/2,b1/2
aslv,r
lslar,r
lsel,r,loc,z,b0/2+0.01,b1/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,z,b0/2-0.01,b0/2+0.01
lesize,all,,,4
allsel
aslv,r
lslar,r
lsel,r,loc,z,b1/2-0.01,b1/2-0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
vsel,s,loc,y,-b0/2,b0/2
vsel,r,loc,x,-b1/2,-b0/2
aslv,r
lslar,r
lsel,r,loc,x,-b1/2+0.01,-b0/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,x,-b0/2-0.01,-b0/2+0.01
lesize,all,,,4
allsel
aslv,r
lslar,r
lsel,r,loc,x,-b1/2-0.01,-b1/2+0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
vsel,r,loc,x,b0/2,b1/2
aslv,r
lslar,r
lsel,r,loc,x,b0/2+0.01,b1/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,x,b0/2-0.01,b0/2+0.01
lesize,all,,,4
allsel
aslv,r
lslar,r
lsel,r,loc,x,b1/2-0.01,b1/2+0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
!12个薄板空气
allsel
vsel,s,loc,z,-b0/2,b0/2
vsel,u,loc,x,-b0/2,b0/2
vsel,u,loc,y,-b0/2,b0/2
aslv,r
lslar,r
lsel,u,loc,z,-b0/2+0.01,b0/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,z,-b0/2+0.01,b0/2-0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
vsel,u,loc,z,-b0/2,b0/2
aslv,r
lslar,r
lsel,u,loc,x,-b0/2+0.01,b0/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,x,-b0/2+0.01,b0/2-0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lsel,u,loc,y,-b0/2+0.01,b0/2-0.01
lesize,all,,,20
allsel
aslv,r
lslar,r
lsel,r,loc,y,-b0/2+0.01,b0/2-0.01
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
!大部分空气
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
type,1
mat,1
vmesh,all
!远场边界
allsel
asel,s,loc,x,-b1/2-0.01,-b1/2+0.01
asel,a,loc,x,b1/2-0.01,b1/2+0.01
asel,a,loc,y,-b1/2-0.01,-b1/2+0.01
asel,a,loc,y,b1/2-0.01,b1/2+0.01
asel,a,loc,z,-b1/2-0.01,-b1/2+0.01
asel,a,loc,z,b1/2-0.01,b1/2+0.01
type,2
amesh,all
!求解
/solu
csys,0
allsel
!静力分析
antype,static
!施加边界条件
!棱边法
!垂直边界自动满足
!施加平行边界
allsel
nsel,s,loc,x,-b1/2-0.01,-b1/2+0.01
nsel,a,loc,x,b1/2-0.01,b1/2+0.01
nsel,a,loc,y,-b1/2-0.01,-b1/2+0.01
nsel,a,loc,y,b1/2-0.01,b1/2+0.01
nsel,a,loc,z,-b1/2-0.01,-b1/2+0.01
nsel,a,loc,z,b1/2-0.01,b1/2+0.01
d,all,az,0
!选择求解器
allsel
!矢量法或棱边法
magsolv,0
!后处理
/post1
!提取节点编号
csys,0
rsys,0
nx=3
ny=3
nz=3
noden=node(nx,ny,nz)
!提取磁感应强度
*get,bx1,node,noden,b,x
*get,by1,node,noden,b,y
*get,bz1,node,noden,b,z
*get,bs1,node,noden,b,sum
!提取磁场强度
*get,hx1,node,noden,h,x
*get,hy1,node,noden,h,y
*get,hz1,node,noden,h,z
*get,hs1,node,noden,h,sum
!写入到文件
*create,ansuitmp
*cfopen,d:\ansys\data,txt
*vwrite,noden,nx,ny,nz,bx1,by1,bz1,bs1,hx1,hy1,hz1,hs1
(f20.0,/f20.5,/f20.5,/f20.5,/e25.5,/e25.5,/e25.5,/e25.5,/e25.5,/e25.5,/e25.5,/e25.5)
*cfclos
*end
/input,ansuitmp
!****end****
!****标量法****
/prep7
emunit,mks
!空气边界
b1=10
!磁铁尺寸
b0=0.1
!1个磁铁
!三维分析
!设置单元属性
!磁铁和空气
!磁实体标量
et,1,solid96
!远场边界
et,2,infin47
!设置材料属性
!空气
mp,murx,1,1.0
!永磁铁
mp,murx,2,1.143
mp,mgxx,2,0
mp,mgyy,2,780000
mp,mgzz,2,0
!建立几何模型
wpoffs,,,-b0/2
vsbw,all,
wpcsys,-1
wpoffs,,,b0/2
vsbw,all,
wpcsys,-1
wpoffs,-b0/2
wprota,,,90
vsbw,all,
wpcsys,-1
wpoffs,b0/2
wprota,,,90
vsbw,all,
wpcsys,-1
wpoffs,,-b0/2
wprota,,90
vsbw,all,
wpcsys,-1
wpoffs,,b0/2
wprota,,90
vsbw,all,
wpcsys,-1
!建立有限元模型
!磁铁
csys,0
allsel
aslv,r
lslar,r
lesize,all,,,4
type,1
mat,2
vmesh,all
!6个小条空气
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
!12个薄板空气
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
aslv,r
lslar,r
lesize,all,,,4
allsel
type,1
mat,1
vmesh,all
!大部分空气
allsel
aslv,r
lslar,r
lesize,all,,,20
allsel
type,1
mat,1
vmesh,all
!远场边界
allsel
type,2
amesh,all
!求解
/solu
csys,0
allsel
!静力分析
antype,static
!施加边界条件
!标量法
!平行边界自动满足
!施加垂直边界
allsel
d,all,mag,0
!选择求解器
allsel
!简化标量法
magsolv,2
!后处理
/post1
!提取节点编号
csys,0
rsys,0
nx=3
ny=3
nz=3
!提取磁感应强度
!提取磁场强度
!写入到文件
*create,ansuitmp
*cfclos
*end
/input,ansuitmp
!****end**** |
