命令流如下
!定义坐标范围
xmin=0
xmax=1.676e-2
ymin=0
ymax=1.676e-2
zmin=0
zmax=1.676e-2
jmin=0
jmax=6.28318
hmin=0
hmax=3.14159
smin=0
smax=3.14159
!定义纤维个数
num=3000
!定义纤维单肢长度
l=0.5e-2
!定义纤维转角
u=1.04720
!存放纤维端点及其数组
*dim,point,array,num,3
*dim,angle,array,num,3
*dim,abc,array,num,1
cum=0
*do,i,1,1000000000000
*if,cum,eq,num,then
*exit
*endif
x=rand(xmin,xmax)
y=rand(ymin,ymax)
z=rand(zmin,zmax)
j=rand(jmin,jmax)
h=rand(hmin,hmax)
s=rand(smin,smax)
*if,(-0.5-cos(h)*cos(s))/(sin(h)*sin(s)),gt,-1,and,(-0.5-cos(h)*cos(s))/(sin(h)*sin(s)),lt,1,then
*if,x+l*sin(h)*cos(j),ge,xmin,and,x+l*sin(h)*cos(j),le,xmax,then
*if,y+l*sin(h)*sin(j),ge,ymin,and,y+l*sin(h)*sin(j),le,ymax,then
*if,z+l*cos(h),ge,zmin,and,z+l*cos(h),le,zmax,then
*if,x+l*sin(s)*cos(j-acos((-0.5-cos(h)*cos(s))/(sin(h)*sin(s)))),ge,xmin,and,x+l*sin(s)*cos(j-acos((-0.5-cos(h)*cos(s))/(sin(h)*sin(s)))),le,xmax,then
*if,y+l*sin(s)*sin(j-acos((-0.5-cos(h)*cos(s))/(sin(h)*sin(s)))),ge,ymin,and,y+l*sin(s)*sin(j-acos((-0.5-cos(h)*cos(s))/(sin(h)*sin(s)))),le,ymax,then
*if,z+l*cos(s),ge,zmin,and,z+l*cos(s),le,zmax,then
cum=cum+1
point(cum,1)=x
point(cum,2)=y
point(cum,3)=z
angle(cum,1)=j
angle(cum,2)=h
angle(cum,3)=s
*else
*endif
*endif
*endif
*endif
*endif
*endif
*endif
*enddo
/prep7
!选择单元类型
et,1,link68
!定义实常数
r,1,7.85e-9
!定义电阻率
mp,rsvx,1,1e-7
uimp,1,kxx,,,1e3
*do,i,1,num
abc(i,1)=angle(i,1)-acos((-0.5-cos(angle(i,2))*cos(angle(i,3)))/(sin(angle(i,2))*sin(angle(i,3))))
!生成关键点
k,point,point(i,1),point(i,2),point(i,3)
k,point1,point(i,1)+l*sin(angle(i,2))*cos(angle(i,1)),point(i,2)+l*sin(angle(i,2))*sin(angle(i,1)),point(i,3)+l*cos(angle(i,2))
k,point2,point(i,1)+l*sin(angle(i,3))*cos(abc(i,1)),point(i,2)+l*sin(angle(i,3))*sin(abc(i,1)),point(i,3)+l*cos(angle(i,3))
*enddo
!连接关键点生成线
*do,n,1,8997,3
lstr,n,n+1
lstr,n,n+2
*enddo
!布尔运算使纤维接触
btol,1e-5
!分配单元属性
latt,1,1,1
!划分网格
lesize,all,,,50
lmesh,all
nummrg,node,0.577e-5,1e-5,,low
nummrg,kp,0.577e-5,1e-5,,low
numcmp,all
!选择单元类型
et,2,solid69
!定义电阻率
mp,rsvx,2,1e4
uimp,2,kxx,,,2.33
!生成实体
BLC4,0,0,1.676e-2,1.676e-2,1.676e-2
/trlcy,volu,1,1
!分配单元属性
vatt,2,,2
!划分网格
esize,,30
!选择先映射后自由网格划分
mshkey,2
!选择3d六面体单元
mshape,0,3d
vmesh,all
!合并编号重复节点
numcmp,all
finish
!进入求解器
/solu
!在面4上施加200电压
asel,s,area,,4
da,all,volt,200
!在面3上施加0电压
asel,s,area,,3
da,all,volt,0
asel,all
solve
finish
/post1
