查看: 163|回复: 2
[声学] 径向极化(取X方向)的圆管状换能器,水中分析(附全部命
发表于 2012-6-7 12:04:00 | 显示全部楼层 |阅读模式 来自 山东青岛
用ANSYS模拟径向极化(取X方向)的圆管状换能器,出现以下问题。该命令是根据GUI操作后提取出来,可以直接粘贴使用,分析过程中遇到如下问题
1、得到的导纳曲线与空气中导纳相差较大(空气中呼吸态频率大约22300左右);
2、模态分没有结果,不管取多大频率范围,总是说求解的范围没有解;
3、网格的划分以及改变流体属性时存在很多警告;
4、针对圆管有没有更好的建模方法;
5分析过程中为减少计算量,进行了对称分析,求解结束后想要观察全部模型的变形,应该怎么操作。
谢谢大家!
/PREP7
ET,1,SOLID5,3
ET,3,FLUID30,
R,3,
ET,4,FLUID30,,1,
R,4,
ET,5,FLUID130
R,5,0.2,0,0,0 !流体半径取200mm
/PREP7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7750
TB,ANEL,1,1,21,0
TBTEMP,0
TBDATA,,11.1e10,7.52e10,7.52e10,0,0,0
TBDATA,,12.1e10,7.54e10,0,0,0,12.1e10
TBDATA,,0,0,0,2.11e10,0,0
TBDATA,,2.26e10,0,2.11e10,,,
TB,PIEZ,1,,,0
TBMODIF,1,1,15.8
TBMODIF,1,2,
TBMODIF,1,3,
TBMODIF,2,1,-5.4
TBMODIF,2,2,
TBMODIF,2,3,
TBMODIF,3,1,-5.4
TBMODIF,3,2,
TBMODIF,3,3,
TBMODIF,4,1,
TBMODIF,4,2,12.3
TBMODIF,4,3,
TBMODIF,5,1,
TBMODIF,5,2,
TBMODIF,5,3,
TBMODIF,6,1,
TBMODIF,6,2,
TBMODIF,6,3,12.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,PERX,1,,1700
MPDE,PERY,1
MPDATA,PERY,1,,1730
MPDE,PERZ,1
MPDATA,PERZ,1,,1730
MP,SONC,3,1500        !定义流固耦合面流体属性
MP,DENS,3,1000
MP,MU,3,0
MP,SONC,4,1500        !定义流体属性
MP,DENS,4,1000
MP,MU,4,0
MP,SONC,5,1500        !定义吸收流体属性
MP,MU,5,1
save
!建立模型
sphere,0.2,,0,90                 !建立1/4球
vsbw,1                           !由工作平面分成两个体
vdele,2,,,1                      !删除z轴下半部分
cylind,0.021,0.018,0,0.2,0,90     !建立1/4圆管
vptn,all                         !进行partion操作
vdele,6,,,1                      !删除顶部多出来的部分
wpoff,0,0,0.019                  !平移工作平面至圆管顶部
vsbw,all                         !由工作平面分割所有体
wpcsys,-1,0
CSWPLA,11,1,1,1,                 !建立圆柱局部坐标系
CSYS,0
alls
VGLUE,ALL
NUMCMP,VOLU
NUMCMP,AREA
NUMCMP,LINE
alls
!属性
VSEL,S, , ,4             !圆管属性
VATT,1,,1,11
VSEL,S, , ,1
VSEL,a, , ,2
VSEL,a, , ,3
VSEL,a, , ,5
VSEL,a, , ,6
VATT,3,3,3,0
ALLS
!划分网格
!先划分线
lsel,s,line,,2
lsel,a,line,,8
lsel,a,line,,18,19
lesize,all,,,18,,,,,1
lsel,s,line,,1
lsel,a,line,,5
lsel,a,line,,34,35
lesize,all,,,3,,,,,1
lsel,s,line,,9,11
lsel,a,line,,33
lsel,a,line,,36
lesize,all,,,19,,,,,1
lsel,s,line,,24
lsel,a,line,,30
lesize,all,,,30,,,,,1
lsel,s,line,,17
lsel,a,line,,23
lsel,s,line,,12
lsel,a,line,,29
lsel,s,line,,13,15
lsel,s,line,,20,21
lsel,s,line,,26,27
alls
VPLOT
!划分体
vsel,,,,4
vsweep,all
vsel,,,,1
VSWEEP,1,4,5
vsel,s,,,2
vsel,a,,,6
vsweep,all
vsel,,,,5
vsweep,all
alls
asel,,,,10
mshkey,1
mshape,0
amesh,all
vsweep,3,10,9
aclear,10!删除面单元
ALLS
EPLOT
!转换属性,这个操作会产生很多警告
VSEL,ALL
ESEL,S,TYPE,,1
NSLE,S
ESLN,S,0
NSLE,S
ESEL,INVE
NSLE,S
EMODIF,ALL,TYPE,4
EMODIF,ALL,REAL,4
ESEL,ALL
NSEL,ALL
CSYS,2
NSEL,S,LOC,X,0.2
REAL,5
TYPE,5
MAT,4
ESURF
ALLS
CSYS,0
!流固耦合标示符
ASEL,S, , ,     21
NSLA,S,1
NPLOT
ESEL,S,TYPE,,3
SF,ALL,FSI
ASEL,S, , ,     3
NSLA,S,1
NPLOT
ESEL,S,TYPE,,3
SF,ALL,FSI
ASEL,S, , ,    19
NSLA,S,1
NPLOT
ESEL,S,TYPE,,3
SF,ALL,FSI
alls
!分别耦合圆管内外表面电压电压
asel,s,,,21
nsla,s,1
nplot
nsel,u,loc,z,0.019!去除圆管顶部的节点
nplot
cp,1,volt,all
*get,n1,node,0,num,min
asel,s,,,3
nsla,s,1
nplot
nplot
cp,2,volt,all
*get,n2,node,0,num,min
alls
D,n1,VOLT,0
D,n2,VOLT,0
alls
eplot
!对称操作
NSEL,S,LOC,X,0
DSYM,SYMM,X
NSEL,S,LOC,Y,0
DSYM,SYMM,Y
NSEL,S,LOC,Z,0
DSYM,SYMM,Z
ALLS
!求解
!模态分析
/SOLU
D,n1,VOLT,10
D,n2,VOLT,0
ANTYPE,2
MODOPT,DAMP,15,10000,40000,,OFF
MXPAND,15
SOLVE
FINISH
!谐响应分析
/solu
D,n1,VOLT,10
D,n2,VOLT,0
ANTYPE,3
HROPT,FULL
HROUT,ON
LUMPM,0
EQSLV, ,1e-008,
PSTRES,0
HARFRQ,15000,35000,
NSUBST,100,
KBC,1
SOLVE
FINISH
!提取导纳
/POST26
RFOR,2,8*n1,AMPS,        !得到电荷值
CFACT,2*3.14159265/10,0,0,-1, !相关系数
PROD,3,2,1,,GB,               !导纳PROD,3,2,1,,GB,
REALVAR,4,3,,,G     !电导(实部)
IMAGIN,5,3,,,B     !电纳(虚部)
发表于 2014-11-16 15:55:58 | 显示全部楼层 来自 浙江杭州
不会命令流是硬伤啊!!!
GMT+8, 2024-7-1 01:22 , Processed in 0.027383 second(s), 11 queries , Gzip On, MemCache On.
