/prep7
!Input the scalar which determine the shape of the equipment
I1=1000
I2=500
myfreq=450e3 !频率
myPI=3.14159265358979 !圆周率
myMuro=4*myPI*1e-7 !真空相对磁导率
myKB=1.38e-23 !波尔兹曼常数
myEta=0.00235 !液体的粘度系数
myR=7e-9 !粒子的平均半径
myTao0=10e-9 !奈尔弛豫时间常数,典型值10e(-9~-10)
myDelta=2e-9 !表面活性剂厚度
myYX=0.2 !材料的奈尔各向异性系数
myFI=0.071 !磁流体的体积百分数
myMd=414e3 !材料畴磁化率
!下面参数应随计算而变,现作为常量计算
myT=310 !组织温度
!以下为导出数据
!以下参数为随着温度而变化的各个参数,本程序把温度当做常数
myVm=4*myPI*myR**3/3 !离子体积
myVh=myVm*(1+myDelta/myR)**3 !流体力学体积
myTb=3*myEta*myVh/myKB/myT !布朗弛豫时间
myG=myYX*myVm/myKB/myT !奈尔弛豫时间中间变量计算
myTn=sqrt(myPI)*myTao0*exp(myG)/sqrt(myG)/2 !奈尔弛豫时间(与论文大致对应)
myXi=myMuro*myFI*myVm*myMd**2/myKB/myT/3 !实际磁化率系数(实际上它应该随着温度而变化);另外,还有一个值myKxi须与H结合才能算出
myTao=1/(1/myTb+1/myTn) !弛豫时间
!The size of main coils
L1=0.2 !The length of the main coil(constant)
W1=0.05 !The width of the main coil(constant)
!The size of correcting coils
L2=0.1 !The length of the correcting coil(constant)
W2=0.025 !The width of the correcting coil(constant)
!The size of the cancer lesions
Rx=0.1 !the radius of tumor in liver
Lx=0.1 !the length of tumor in liver
Ry=0.15 !the radius of liver
Ly=0.2 !the length of liver
!The controlled size
r1=0.25 !the min radius value of mail coil(variable,[0.25,0.5])
z1=0.15 !the distance of the main coil from the axis(variable,[0.15,0.4])
dr=0.05 !the gap betreen main and correcting coil(constant,[0.05])
dz=0.45 !the shift distance of the correcting coil with respect the main one(variable,[-0.05,0.45])
csys,0
/pnum,area,1
p1=z1+dz+L2
p2=r1+W1+dr+W2
p3=sqrt(p1*p1+p2*p2)
temp_scale=2.0 !air element's area factor
infin_scale=1.2 !infinte element's area factor
cyl4,0,0,0,0,temp_scale*p3,90
cyl4,0,0,0,0,infin_scale*temp_scale*p3,90
aovlap,all
numcmp,all
rectng,0,Lx/2,0,Rx
rectng,0,Ly/2,0,Ry
rectng,z1,z1+L1,r1,r1+W1
rectng,z1+dz,z1+dz+L2,r1+W1+dr,r1+W1+dr+W2
aovlap,all
numcmp,all
!AGEN, ITIME, NA1, NA2, NINC, DX, DY, DZ, KINC, NOELEM, IMOVE
asel,all
csys,1
agen,2,all,,,,90,,,0,1
csys,0
arsym,x,all,,,,0,1
/replot
!mat assignment
et,1,110,0,,1 !the infinite area
et,2,13,4,,1 !the main coil
et,3,13,4,,1 !the correcting coil
et,4,13,4,,1 !the cancer full of ferromagnetic fliud
et,5,13,4,,1 !the liver
et,6,53,0,,1 !the air
mp,murx,1,1
mp,murx,2,1
mp,rsvz,3,1.7e-8 !the correcting coil's Electrical resistivities
mp,murx,3,1
mp,murx,4,1 !ferromagnetic(the material is air now)
mp,murx,5,1 !human body's material characteristic:murx
mp,murx,6,1 !the air
asel,s,area,,1
aatt,1,,1
asel,s,area,,2
aatt,2,2,2
asel,s,area,,3
aatt,3,3,3
asel,s,area,,4
aatt,4,4,4
asel,s,area,,5
aatt,5,5,5
asel,s,area,,6
aatt,6,,6
allsel,all
lsel,all
lsel,u,line,,1,4,1
lsel,u,line,,21,22
lesize,all,0.01
lsel,s,line,,1,2
lsel,a,line,,21,22
lesize,all,,,30
lsel,s,line,,3,4
lesize,all,,,1 !LESIZE, NL1, SIZE, ANGSIZ, NDIV, SPACE, KFORC, LAYER1, LAYER2, KYNDIV
allsel,all
!mshape,0,2d
!mshkey,2
smartsize,2
amesh,all
csys,1
allsel,all
lsel,s,loc,x,infin_scale*temp_scale*p3
nsll,s,1
sf,all,inf
lsel,s,loc,y,90
nsll,s,1
d,all,az,0
csys,0
asel,s,area,,2
asum
*get,areaOfmain,area,2,area
asel,s,area,,3
asum
*get,areaOfcorr,area,3,area
densOfmain=I1/areaOfmain
densOfcorr=I2/areaOfcorr
allsel,all
asel,s,area,,2
esla
bfe,all,JS,1,,,densOfmain
asel,s,area,,3
esla
bfe,all,JS,1,,,densOfcorr
allsel,all
!!!!以上建立磁场分析模型!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
physics,write,myMagnetics !写物理环境文件
!以下建立热场分析模型
physics,clear !清除边界条件
et,1,0 !磁场计算中的材料1不参与热计算,以下定义材料为零的相同
et,2,0
et,3,0
et,4,77,,,1
et,5,77,,,1
et,6,0
!R, NSET, R1, R2, R3, R4, R5, R6
!MP, Lab, MAT, C0, C1, C2, C3, C4
/units,si
mp,dens,4,1e3
mp,kxx,4,57
mp,c,4,3500
mp,dens,5,1e3
mp,kxx,5,512
mp,c,5,3816
allsel,all
save
finish
physics,write,myTemp
!求解磁场
/solu
physics,read,myMagnetics
antype,harmic,new
allsel,all
hmagsolv,myfreq
finish
/post1
set,last,1,,0
plf2d
!以下为抓图命令,还可以用/ui或者/image抓图,但清晰度比较差
/UI,COPY,SAVE,BMP,GRAPH,COLOR,NORM,PORTRAIT,no,100
PLVECT,H, , , ,VECT,ELEM,ON,0
PLVECT,B, , , ,VECT,ELEM,ON,0
!以下得到单元标号及其计算结果(Hsum)
asel,s,area,,4
esla,s
etable,myelem,h,sum
*get,NumMin,elem,0,num,min !得到区域中最小单元编号
*get,NumCount,elem,0,count !得到被选中的全部单元总数
*dim,p1Elem,,NumCount,2 !NumCount行2列数组,分别储存单元编号,场计算值
p1Elem(1,1)=NumMin
*do,i,2,NumCount
p1Elem(i,1)=elnext(p1Elem(i-1,1))
*enddo
*do,i,1,NumCount
*get,p1Elem(i,2),etab,1,elem,p1Elem(i,1)
*enddo
*dim,temp_H,,NumCount
*do,i,1,NumCount
temp_H(i)=p1Elem(i,2)
*enddo
!以下得到Hsum平均值
*VSCFUN,meanOfH,mean,temp_H
*VSCFUN,elemOfMaxH,max,temp_H
*VSCFUN,elemOfMinH,min,temp_H
JunYunDu=(elemOfMaxH-elemOfMinH)/meanOfH !磁场不均匀度
!以下计算各个单元的热流率P
*dim,densRateOfHF,,NumCount
*do,i,1,NumCount
myKxi=myMuro*myMd*p1Elem(i,2)*myVm/myKB/myT
myKi0=myXi*3/myKxi*(1/tanh(myKxi)-1/myKxi)
myKidd=2*myPI*myfreq*myTao/(1+(2*myPI*myfreq*myTao)**2)*myKi0
densOfHF=myMuro*myPI*myKidd*myfreq*p1Elem(i,2)**2
*get,areaOfElem,elem,p1Elem(i,1),area
densRateOfHF(i)=densOfHF/areaOfElem
*enddo
finish
/solu
antype,static
physics,read,myTemp
nsel,all
tunif,myT !定义所有节点初始温度(K)
lsel,s,loc,y,Ly/2
lsel,a,loc,x,Ry
nsll,s,1
d,all,temp,myT !定义体温边界条件(K)
allsel,all
nropt,auto
autots,on
kbc,0
nsubst,50
allsel,all
*do,i,1,NumCount
esel,s,elem,,p1Elem(i,1)
sfe,all,,hflux,,densRateOfHF(i)
*enddo
allsel,all
outpr,nsol,last
solve
finish
/post1
PLNSOL, TEMP,, 0
PLNSOL, TG,SUM, 0
PLVECT,TF, , , ,VECT,ELEM,ON,1
PLVECT,TG, , , ,VECT,NODE,ON,1
finish
