下面曲折线圈加载余弦交流电,在磁场作用下感应涡流,但为什么会出现下面图2这种情况?按原理分析感应涡流不应该是图4吗?
这是我的命令流,求高手看看是哪里设置有问题?非常感谢啊
finish
/clear
/filename,EMAT_3D_A0,1 !定义文件名
/title,EMAT_3D_A0 !定义工作名称
/PREP7
!定义单元
ET,1,SOLID117 !钢板
ET,2,SOLID117
!线圈
ET,3,SOLID117 !空气
ET,4,SOLID117 !永磁体
ET,5,SOLID117
ET,6,SOLID117
KEYOPT,1,1,1
KEYOPT,2,1,1
EMUNIT,MKS
MP,MURX,2,1 !线圈
MP,RSVX,2,0.175e-7
MP,MURX,1,1
MP,RSVX,1,0.283e-7 !电阻率
MP,MURX,3,1 !空气
HC=895000
MP,MURX,4,11
MP,MURX,5,11
MP,MURX,6,1000
MP,MGXX,4,0
MP,MGYY,4,HC
MP,MGZZ,4,0
MP,MGXX,5,0
MP,MGYY,5,-HC
MP,MGZZ,5,0
BLOCK,,0.0005,,0.0005,,0.0355 !!!线圈模型
VGEN,12,ALL,,,0.0030,,,,0
VSEL,NONE
BLOCK,,0.0035,,0.0005,-0.0005,0
VGEN,6,ALL,,,0.0060,,,,0
VSEL,NONE
BLOCK,0.0030,0.0065,,0.0005,0.0355,0.0360
VGEN,5,ALL,,,0.0060,,,,0
VSEL,NONE
BLOCK,0.0035,0.0060,,0.0005,-0.0005,0
VSEL,NONE
BLOCK,,0.0005,,0.0005,0.0355,0.0360
VGEN,2,ALL,,,0.0330,,,,0
VSEL,NONE
BLOCK,0.0005,0.0030,,0.0005,,0.0355
VGEN,11,ALL,,,0.0030,,,,0
VSEL,NONE
BLOCK,0.0005,0.0030,,0.0005,0.0355,0.0360
ALLSEL
VGLUE,ALL
NUMCMP,VOLU
!磁铁
BLOCK,-0.0450,-0.0050,,0.0150,-0.0070,0.0430
BLOCK,0.0385,0.0785,,0.0150,-0.0070,0.0430
BLOCK,-0.0450,0.0785,0.0150,0.0350,-0.0070,0.0430
!钢板模型
BLOCK,-0.0600,0.0935,-0.0010,-0.0310,-0.0240,0.0600
!空气模型
BLOCK,-0.0050,0.0385,,0.0150,-0.0070,0.0430 !线圈上空气
BLOCK,-0.0600,0.0935,-0.0010,0,-0.0240,0.0600!钢板上空气
BLOCK,-0.25,0.25,-0.25,0.25,-0.25,0.25
VOVLAP,ALL !布尔搭接操作
NUMCMP,VOLU
VSEL,S,,,54
VSEL,INVE
VSEL,U,,,53
VSEL,U,,,51
!为实体分配单元属性
!线圈
VSEL,S,,,1,13,1
VSEL,A,,,25
VSEL,A,,,37,47,1
VATT,2,,2,0
!永磁体
VSEL,S,,,48
VATT,4,,4,0
VSEL,S,,,49
VATT,5,,5,0
VSEL,S,,,51
VATT,6,,6,0
!钢板
VSEL,S,,,50
VATT,1,,1,0
!空气
VSEL,S,MAT,,1
VSEL,A,MAT,,2
VSEL,A,MAT,,4
VSEL,A,MAT,,5
VSEL,A,MAT,,6
VSEL,INVE
VATT,3,,3,0
!网格划分
!钢板
LSEL,S,,,211
LSEL,A,,,215
LESIZE,ALL,,,40,,,,,0
LSEL,S,,,210
LESIZE,ALL,,,10,,,,,0
ALLSEL
MSHAPE,0,3D
MSHK,1
VMESH,50
VSEL,S,,,1,49,1
VSEL,A,,,51,53,1
MSHAPE,1,3D
MSHK,0
VMESH,ALL
VSEL,S,,,54
SMRT,4
VMESH,ALL
!加电压耦合
ASEL,S,,,170
NSLA,S,1
CP,1,VOLT,ALL
!求解
FINISH
/SOL !进入求解器
ALLSEL
ANTYPE,TRANS
OUTRES,ALL,,
TRNOPT,FULL
ALLSEL
TM_START=1E-6
TM_END=1.25E-2
TM_INCR=0.069995E-2
PHI=0
AUTOTS,ON
*DO,TM,TM_START,TM_END,TM_INCR
TIME,TM
PHI=PHI+1
I=4*COS(PHI)
AS=6e-7
JS=I/AS
allsel !选择所有
ANTYPE,4 !选择瞬态分析
LUMPM,0
ASEL,S,EXT !选择所有外表面
DA,all,AZ,0,0 !指定电磁为0边界条件
DA,176,VOLT,0 !线圈另一面指定电压为0
FK,230,AMPS,JS !给线圈耦合面上的一点施加总电流
allsel
NSUBST,2,0,0 !每步指定2子步
OUTRES,ERASE
OUTRES,ALL,1 !输出所有
AUTOTS,0 !关闭自动荷载步
solve !求解
SAVE,EMAT_3D_A0_resu.db
*enddo !结束循环,与*do结合使用
FINISH
