查看: 93|回复: 0
[电磁场] 三维磁热耦合计算有磁场没有热场
发表于 2014-4-8 13:21:06 | 显示全部楼层 |阅读模式 来自 浙江杭州
最近在做三维感应加热的计算,用的单元分别是SOLID117和SOLID90,计算结果,磁场分布基本上是没问题的,可是在载荷传递是磁场没有产生热场,而且在载荷传递时出现下面两个警告:
*** WARNING ***                         CP =      68.781   TIME= 16:57:40
The component MFVO_1_1_HFLU_2 was created for MFVO,1,1,HFLU,2 command
to display improperly mapped nodes.  Set /debug,,2 for more
information on improperly mapped nodes.
*** WARNING ***                         CP =      71.558   TIME= 16:57:43
The component MFVO_1_2_TEMP_1 was created for MFVO,1,2,TEMP,1 command
求问各位大牛,没有热场的产生是不是因为这两个警告?有没有谁碰到过类似问题,肿么解决的?
GMT+8, 2024-7-2 22:10 , Processed in 0.028084 second(s), 11 queries , Gzip On, MemCache On.
