查看: 92|回复: 2
[电磁场] 二维涡流探讨
发表于 2014-10-29 21:26:36 | 显示全部楼层 |阅读模式 来自 陕西西安
有文章讲解说二维涡流场求解分析时,导体(非源区)自由度应该只有az,然后将其材料属性murx,和rsvz即可,并且有书讲‘涡流形成回路,由于短路条件,导体中不存在压降’,因此我将涡流区(非源区)电压设为零。然后进行涡流场分析。可是我每次仿真结果均不对。但是将自由度改为az-volt之后便可以了。
 楼主| 发表于 2014-10-29 21:27:19 | 显示全部楼层 来自 陕西西安
2,3,4,图是自由度改为AZ-VOLT的图
 楼主| 发表于 2014-10-29 21:28:15 | 显示全部楼层 来自 陕西西安
现将命令流附上:
FINISH
/CLEAR
/PREP7
ET,1,233,,,1
ET,2,233,1,,1
MP,MURX,1,1.0
MP,MURX,2,1.0
MP,RSVZ,2,17.1E-8
RECTNG,0,0.1,0,0.2
RECTNG,0.15,0.2,0,0.2
RECTNG,0,1.0,0,1.0
aovlap,ALL
NUMCMP,ALL
/pnum,area,1
ASEL,S,,,2
AATT,2,,2
ALLS
ASEL,S,,,1
AATT,2,,2
ALLS
LSEL,S,LOC,X,0.05,0.08
LSEL,R,LOC,Y,0.2
LESIZE,ALL,,,20,10
ALLS
LSEL,R,LOC,Y,0
LESIZE,ALL,,,20,0.1
ALLS
ASEL,S,,,1
LSLA,R
LSEL,R,LOC,X,0
LESIZE,ALL,,,30
ALLS
LSEL,S,LOC,X,0.1
LESIZE,ALL,,,30
ALLS
AMESH,1
LSEL,S,LOC,X,0.16,0.18
LSEL,R,LOC,Y,0.2
LESIZE,ALL,,,20,0.1
LSEL,R,LOC,Y,0
LESIZE,ALL,,,20,10
LSEL,S,LOC,X,0.15
LESIZE,ALL,,,30
LSEL,S,LOC,X,0.2
LESIZE,ALL,,,30
AMESH,2
SMRTSIZE,2
AMESH,3
ASEL,S,,,2
NSLA,R
CP,1,VOLT,ALL
*get,NODE_AMPS,NODE,,num,max
F,NODE_AMPS,AMPS,1000
ALLS
LSEL,S,LOC,X,0
LSEL,A,LOC,X,1.0
LSEL,A,LOC,Y,1.0
NSLL,R
D,ALL,AZ,0
ALLS
ASEL,S,,,1
NSLA,R
D,ALL,VOLT,0
ALLS
/SOLU
ANTYPE,HARMIC
HARFRQ,100
KBC,1
SOLVE
GMT+8, 2024-7-1 15:34 , Processed in 0.026621 second(s), 11 queries , Gzip On, MemCache On.
