我的命令流有什么错吗,请大神们解答
/input,menust,tmp,''
/GRA,POWER
/GST,ON
/PLO,INFO,3
/GRO,CURL,ON
/CPLANE,1
/REPLOT,RESIZE
WPSTYLE,,,,,,,,0
/REPLOT,RESIZE
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,1
/PNUM,VOLU,1
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,MAT,1
/REPLOT
/PREP7
ET,1,SOLID97
KEYOPT,1,1,2
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,1
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,1
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,1
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,1
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,1
KEYOPT,1,1,1
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,5
KEYOPT,1,1,1
KEYOPT,1,2,0
KEYOPT,1,5,0
KEYOPT,1,1,5
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,1,,1.4e-6
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,2,,5.7e-3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,1
~PARAIN,'solid2','x_t','..\..\solidworks work\solid1\yuanzhu1\',SOLIDS,0,0
/NOPR
/GO
/FACET,NORML
/REPLO
BLOCK,0.05,-0.05,-0.05,0.05,0,1.7,
vptn,all
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,1
/PNUM,VOLU,1
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,ELEM,1
/REPLOT
NUMCMP,VOLU
NUMCMP,AREA
vlist, all
FLST,5,2,6,ORDE,2
FITEM,5,2
FITEM,5,5
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,3
FITEM,5,6
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,1
FITEM,5,4
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,3
FITEM,5,6
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,2
FITEM,5,5
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,1
FITEM,5,4
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
wpro,,-90.000000,
wpro,,,45.000000
FLST,2,3,6,ORDE,2
FITEM,2,4
FITEM,2,-6
VSBW,P51X
NUMCMP,AREA
NUMCMP,VOLU
wpro,,,90.000000
FLST,2,6,6,ORDE,2
FITEM,2,4
FITEM,2,-9
VSBW,P51X
NUMCMP,VOLU
NUMCMP,AREA
FLST,2,15,6,ORDE,2
FITEM,2,1
FITEM,2,-15
VGLUE,P51X
VPLOT
ESIZE,0.03,0,
FLST,5,15,6,ORDE,2
FITEM,5,1
FITEM,5,-15
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,1
/PNUM,VOLU,1
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,ELEM,0
/REPLOT
FINISH
/SOL
ANTYPE,3
HARFRQ,0,50,
NSUBST, ,
KBC,0
NSEL,S,LOC,Z,0
FLST,2,160,1,ORDE,16
FITEM,2,445
FITEM,2,-480
FITEM,2,923
FITEM,2,-985
FITEM,2,1041
FITEM,2,-1089
FITEM,2,1922
FITEM,2,-1923
FITEM,2,1926
FITEM,2,2295
FITEM,2,-2297
FITEM,2,2869
FITEM,2,-2870
FITEM,2,2873
FITEM,2,3007
FITEM,2,-3009
/GO
D,P51X,VOLT,0,
NSEL,S,LOC,Z,1.7
FINISH
/PREP7
FLST,4,82,1,ORDE,25
FITEM,4,1
FITEM,4,-30
FITEM,4,1208
FITEM,4,-1221
FITEM,4,1356
FITEM,4,1358
FITEM,4,1456
FITEM,4,-1460
FITEM,4,1466
FITEM,4,1484
FITEM,4,1582
FITEM,4,-1586
FITEM,4,3115
FITEM,4,-3120
FITEM,4,3172
FITEM,4,-3174
FITEM,4,3192
FITEM,4,3227
FITEM,4,-3228
FITEM,4,3331
FITEM,4,-3336
FITEM,4,3354
FITEM,4,3372
FITEM,4,3441
FITEM,4,-3444
CP,1,VOLT,P51X
*SET,NI,NDNEXT(0)
FINISH
/SOL
FLST,2,1,1,ORDE,1
FITEM,2,1
/GO
F,P51X,AMPS,8000, |
