- 56
- 2003-12-29
楼主 |
发表于 2006-11-21 05:38:30
来自 美国
对不起,我用直接加电流的,应该是1 AX, AY, AZ, VOLT自由度,这种比较多
你说的是下面的3和4,按帮助做就可以了。和电路耦合4的好像在电路里面给参考点。3好像就用过一次,实在记不得了
Element degrees of freedom and formulation selection:
Classical Formulation
0 --
AX, AY, AZ degrees of freedom: static domain, source domain
1 --
AX, AY, AZ, VOLT degrees of freedom: eddy current domain, velocity effect domain
2 --
AX, AY, AZ, CURR degrees of freedom: voltage-fed stranded coil
3 --
AX, AY, AZ, CURR, EMF degrees of freedom: circuit-coupled stranded coil
4 --
AX, AY, AZ, VOLT, CURR degrees of freedom: circuit-coupled massive conductor |
