- 39
- 2006-1-20
Download the ANSYS MEMS Material library. The library is in the ANSYS Programing Design Language (APDL) format and contains 20:) common MEMS materials in SI units, bulk, and thin film properties. Linear material properties only. Materials such as Polysilicon:), Silicon Oxide:), nitride :)and thin film metals:). This is intended to be a starting point for your simulation requirements. Each material data file contains the reference :)used for the property(s).
使用方法:
1)Download the archive and unzip into a new folder called "MEMS materials".
2)Put this folder in your ANSYS/Matlib directory.
3)The material data can be accessed from the ANSYS Material library GUI. The Menu path is: Main Menu>Preprocessor>Material Props>Import Library. |
