谢谢楼上的,我是陕西师大的,我加的电压是一个电极加100v,另一个加0v,命令流失这样的:(作了几次,比较杂乱)
/BATCH
/COM,ANSYS RELEASE 9.0 UP20041104 21:04:55 03/19/2007
/input,menust,tmp,'',,,,,,,,,,,,,,,,1
/GRA,POWER
/GST,ON
/PLO,INFO,3
/GRO,CURL,ON
/CPLANE,1
/REPLOT,RESIZE
WPSTYLE,,,,,,,,0
/PREP7
ET,1,SOLID5,3
mp,DENS,1,7500 ! Density, kg/m**3
emunit,epzro,8.85E-12
MP,PERX,1,804.6 ! PERMITTIVITY (X AND Y DIRECTION)
MP,PERZ,1,659.7 ! PERMITTIVITY (Z DIRECTION)
TB,PIEZ,1 ! DEFINE PIEZ. TABLE
TBDATA,16,10.5 ! E61 PIEZOELECTRIC CONSTANT
TBDATA,14,10.5 ! E52 PIEZOELECTRIC CONSTANT
TBDATA,3,-4.1 ! E13 PIEZOELECTRIC CONSTANT
TBDATA,6,-4.1 ! E23 PIEZOELECTRIC CONSTANT
TBDATA,9,14.1 ! E33 PIEZOELECTRIC CONSTANT
TB,ANEL,1 ! DEFINE STRUCTURAL TABLE
TBDATA,1,13.2E10,7.1E10,7.3E10 ! INPUT [C] MATRIX
TBDATA,7,13.2E10,7.3E10
TBDATA,12,11.5E10
TBDATA,16,3.0E10
TBDATA,19,2.6E10
TBDATA,21,2.6E10
SAVE
CYLIND,0.03,0.006,0,0.008,0,90,
SAVE
LPLOT
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
FLST,5,4,4,ORDE,4
FITEM,5,2
FITEM,5,4
FITEM,5,-5
FITEM,5,7
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,1
FITEM,5,3
FITEM,5,6
FITEM,5,8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,4,4,ORDE,2
FITEM,5,9
FITEM,5,-12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,4, , , , ,1
MSHAPE,0,3D
MSHKEY,1
/UI,MESH,OFF
/UI,MESH,OFF
SAVE
FINISH
! /EXIT,MODEL
/BATCH
/COM,ANSYS RELEASE 9.0 UP20041104 21:07:23 03/19/2007
/GRA,POWER
/GST,ON
/PLO,INFO,3
/GRO,CURL,ON
/CPLANE,1
/REPLOT,RESIZE
WPSTYLE,,,,,,,,0
RESUME
/COM,ANSYS RELEASE 9.0 UP20041104 21:07:31 03/19/2007
/SOLU
FINISH
/PREP7
LPLOT
CM,_Y,VOLU
VSEL, , , , 1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SAVE
nsel,s,loc,x,0
dsym,symm,x,0
nsel,s,loc,y,0
dsym,symm,y,0
nsel,all
SAVE
NSEL,S,LOC,Z,0
cp,1,volt,all
*get,n_top,node,0,num,min
NSEL,S,LOC,Z,0.008
cp,2,volt,all
*get,n_bot,node,0,num,min
nsel,all
SAVE
SAVE
FINISH
/SOL
ANTYPE,2
MSAVE,0
MODOPT,LANB,20
EQSLV,SPAR
MXPAND,20, , ,0
LUMPM,0
PSTRES,0
MODOPT,LANB,20,70000,150000, ,OFF
/STATUS,SOLU
SOLVE
FINISH
/POST1
SET,LIST,999
SET,,, ,,, ,7
PLDI,1,
ANMODE,10,0.5, ,0
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/USER, 1
/VIEW, 1, 0.260929502154 , 0.820900603601E-02, 0.965322954832
/ANG, 1, -9.54457421845
/REPLO
/VIEW, 1, 0.207074691996 , -0.694098024994 , 0.689454859751
/ANG, 1, -9.01666088780
/REPLO
/VIEW, 1, 0.298539481877 , -0.774838520504 , 0.557224770540
/ANG, 1, -17.3954711513
/REPLO
/VIEW, 1, 0.127919332868E-01, -0.873150722607 , 0.487282445871
/ANG, 1, 4.77757793703
/REPLO
/VIEW, 1, 0.174318516208 , -0.904622803132 , 0.388935263200
/ANG, 1, -15.3064823658
/REPLO
/VIEW, 1, 0.445416052314 , -0.772169661177 , 0.453165041347
/ANG, 1, -30.7844383989
/REPLO
/VIEW, 1, 0.183887041978 , -0.720394120173 , 0.668743498969
/ANG, 1, -7.33382661885
/REPLO
/VIEW, 1, 0.299816513685 , -0.953752937412 , 0.215729576048E-01
/ANG, 1, -79.6341510036
/REPLO
/VIEW, 1, 0.653067238339 , -0.694332244227 , 0.302334114572
/ANG, 1, -61.7386693823
/REPLO
/VIEW, 1, 0.385218962051 , -0.843141819685 , 0.375124276974
/ANG, 1, -46.3027182399
/REPLO
/VIEW, 1, 0.267562658895 , -0.865394240267 , 0.423677982054
/ANG, 1, -34.8707007998
/REPLO
/VIEW, 1, 0.205220784839 , -0.875119072572 , 0.438236281350
/ANG, 1, -28.6351619677
/REPLO
/VIEW, 1, 0.198017879239 , -0.846723808111 , 0.493809388610
/ANG, 1, -25.8414139160
/REPLO
/UI,COPY,SAVE,JPEG,GRAPH,GREY,NORM,LANDSCAPE,,100
/VIEW,1,,,1
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
SET,LIST
SET,LAST
PLDI,1,
ANMODE,10,0.5E-01, ,0
SET,PREVIOUS
PLDI,1,
SET,PREVIOUS
PLDI,1,
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
PLDI,1,
SET,LIST
/VIEW,1,1
/ANG,1
/REP,FAST
SET,FIRST
PLDI,1,
SET,NEXT
PLDI,1,
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
SET,NEXT
PLDI,1,
/VIEW,1,,,1
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
SET,NEXT
PLDI,1,
SET,NEXT
PLDI,1,
SET,NEXT
PLDI,1,
SET,NEXT
PLDI,1,
FINISH
/SOL
ANTYPE,2
MSAVE,0
MODOPT,LANB,20
EQSLV,SPAR
MXPAND,20, , ,0
LUMPM,0
PSTRES,0
NSEL,S,LOC,Z,0
d,n_top,volt,100
NSEL,S,LOC,Z,0.008
d,n_bot,volt,0
nsel,all
/STATUS,SOLU
SOLVE
/VIEW,1,,,1
/ANG,1
/REP,FAST
FINISH
/POST1
SET,FIRST
SET,LIST
SET,LIST,999
SET,,, ,,, ,7
PLDI,1,
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/DIST,1,0.924021086472,1
/REP,FAST
/REP,FAST
/REP,FAST
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
PLDI,1,
/VIEW, 1, -0.381320622974 , -0.719840707473 , 0.580020636149
/ANG, 1, 10.0874749933
/REPLO
/VIEW, 1, 0.214570907820 , -0.882690160661 , 0.418111714485
/ANG, 1, -40.0136175392
/REPLO
/VIEW, 1, 0.536897321259 , -0.789105137145 , 0.298419752960
/ANG, 1, -68.8913278906
/REPLO
/VIEW, 1, 0.382289859238 , -0.921034855470 , 0.744933455651E-01
/ANG, 1, -84.4283037166
/REPLO
/VIEW, 1, -0.324199614420 , -0.933126563937 , 0.155465191234
/ANG, 1, 54.9219438043
/REPLO
/VIEW, 1, -0.277047230322 , -0.848017608070 , 0.451786419200
/ANG, 1, 24.2785817340
/REPLO
/VIEW, 1, -0.308490759940E-01, -0.865307806155 , 0.500290650641
/ANG, 1, 0.150796561926
/REPLO
/VIEW, 1, 0.523015894880E-01, -0.801802654510 , 0.595295764270
/ANG, 1, -7.13806043340
/REPLO
PLDI,1,
/UI,COPY,SAVE,PNG,GRAPH,GREY,NORM,LANDSCAPE,YES
/REP,FAST
PLDI,1,
FINISH
/SOL
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
SAVE
ANTYPE,3
HROPT,FULL
HROUT,ON
LUMPM,0
EQSLV,FRONT,0,
PSTRES,0
ALPHAD,0,
BETAD,0,
DMPRAT,0.003,
HARFRQ,70000,100000,
NSUBST,30,
KBC,1
/STATUS,SOLU
SOLVE
FINISH
/POST26
FILE,'sang','rst','.'
/UI,COLL,1
NUMVAR,200
SOLU,191,NCMIT
STORE,MERGE
PLCPLX,0
PRCPLX,1
FILLDATA,191,,,,1,1
REALVAR,191,191
RFORCE,2,1,AMPS,, AMPS_2
STORE,MERGE
FILLDATA,192,,,,0,0
FILLDATA,193,,,,1,0
FILLDATA,194,,,,-1,0
FILLDATA,195,,,,1,1
VARNAME,195,NSET
! Name: Y
! ID: 3
! Function: -4*2*3.14*{FREQ}*{AMPS_2}*1000*sqrt(-1)
FILLDATA,199,,,,2,0
REALVAR,199,199
FILLDATA,198,,,,-4,0
REALVAR,198,198
PROD,200,198,199
FILLDATA,198,,,,3.14,0
REALVAR,198,198
PROD,199,200,198
PROD,198,199,1
PROD,199,198,2
FILLDATA,200,,,,1000,0
REALVAR,200,200
PROD,198,199,200
FILLDATA,199,,,,1,0
REALVAR,199,199
FILLDATA,197,,,,0,0
REALVAR,197,197
PROD,196,199,194
ADD,200,197,196
FILLDATA,197,,,,1,0
REALVAR,197,197
PROD,196,200,197
SQRT,197,196
PROD,3,198,197,,Y
STORE,MERGE
XVAR,1
PLVAR,3,
NUMVAR,200
PLCPLX,0
PRCPLX,1
FILLDATA,191,,,,1,1
REALVAR,191,191
FILLDATA,192,,,,0,0
FILLDATA,193,,,,1,0
FILLDATA,195,,,,1,1
VARNAME,195,NSET
! Name: G
! ID: 4
! Function: real({Y})
REALVAR,4,3,,,G
STORE,MERGE
FILLDATA,192,,,,0,0
FILLDATA,193,,,,1,0
FILLDATA,195,,,,1,1
VARNAME,195,NSET
! Name: B
! ID: 5
! Function: imag({Y})
IMAGIN,5,3,,,B
STORE,MERGE
XVAR,1
PLVAR,4,
XVAR,1
PLVAR,5,
XVAR,4
PLVAR,5,
FINISH
/SOL
ANTYPE,3
HROPT,FULL
HROUT,ON
LUMPM,0
EQSLV,FRONT,1e-008,
PSTRES,0
ALPHAD,0,
BETAD,0,
DMPRAT,0.003,
HARFRQ,80000,90000,
NSUBST,50,
KBC,1
/STATUS,SOLU
! PLVAR,5,
FINISH
/POST26
/UI,COLL,1
NUMVAR,200
SOLU,191,NCMIT
STORE,MERGE
PLCPLX,0
PRCPLX,1
FILLDATA,191,,,,1,1
REALVAR,191,191
STORE,MERGE
FILLDATA,192,,,,0,0
FILLDATA,193,,,,1,0
FILLDATA,195,,,,1,1
VARNAME,195,NSET
! Name: Y
! ID: 3
FILLDATA,199,,,,2,0
REALVAR,199,199
REALVAR,198,198
PROD,200,198,199
REALVAR,198,198
PROD,199,200,198
PROD,198,199,1
PROD,199,198,2
REALVAR,200,200
PROD,198,199,200
FILLDATA,199,,,,1,0
REALVAR,199,199
FILLDATA,197,,,,0,0
REALVAR,197,197
PROD,196,199,194
ADD,200,197,196
FILLDATA,197,,,,1,0
REALVAR,197,197
PROD,196,200,197
SQRT,197,196
PROD,3,198,197,,Y
STORE,MERGE
XVAR,1
PLVAR,3,
FILLDATA,192,,,,0,0
FILLDATA,193,,,,1,0
FILLDATA,195,,,,1,1
VARNAME,195,NSET
! Name: G
! ID: 4
REALVAR,4,3,,,G
STORE,MERGE
FILLDATA,192,,,,0,0
FILLDATA,193,,,,1,0
FILLDATA,195,,,,1,1
VARNAME,195,NSET
! Name: B
! ID: 5
IMAGIN,5,3,,,B
STORE,MERGE
XVAR,1
PLVAR,4,
XVAR,1
PLVAR,5,
XVAR,1
PLVAR,4,5,
XVAR,4
PLVAR,5,
XVAR,5
PLVAR,5,
XVAR,5
PLVAR,4,
XVAR,4
PLVAR,4,
XVAR,4
PLVAR,1,
XVAR,4
PLVAR,4,
XVAR,1
PLVAR,4,
XVAR,1
PLVAR,4,5,
/UI,COPY,SAVE,JPEG,GRAPH,COLOR,NORM,LANDSCAPE,,100
XVAR,4
PLVAR,5,
FINISH
! /EXIT,ALL
/BATCH
/COM,ANSYS RELEASE 9.0 UP20041104 18:37:48 03/21/2007
/GRA,POWER
/GST,ON
/PLO,INFO,3
/GRO,CURL,ON
/CPLANE,1
/REPLOT,RESIZE
WPSTYLE,,,,,,,,0
RESUME
/COM,ANSYS RELEASE 9.0 UP20041104 18:37:59 03/21/2007
/REPLOT,RESIZE
/POST26
/UI,COLL,1
NUMVAR,200
SOLU,191,NCMIT
STORE,MERGE
PLCPLX,0
PRCPLX,1
FILLDATA,191,,,,1,1
REALVAR,191,191
FINISH
! /EXIT,MODEL |
