现在我想在三个压电陶瓷中加载两个100sinwt和100coswt的交变电压。(相位相差90度)
压电陶瓷是沿z向极化的。其中第一和第三压电陶瓷极化方向相反,加载100coswt。第二个极化方向与第一个压电陶瓷相同,但要加载100sinwt。
因为刚刚接触压电分析。所以又很多问题不太懂。麻烦大家指点
1、极化方向方面:
压电陶瓷我选用pzt-8,参数按照书上查得。陶瓷伸长方向沿总体笛卡尔坐标系的z轴。这样的话我的电压是不是应该加在两个侧面?
2、压电陶瓷变形引起底板变形。所以我体之间用了vglue对吗?
3、就是电压的加载形式。我直接选择面。这样对吗?
4、就是我现在最不知道的。。
相位相差90度的电压应该怎么加载呢?
附上和压电陶瓷有关的命令流(自己编的不太规范,大家别见笑)
以及模型
命令流:
et,2,solid5,3
MP,DENS,3,7500 !+
MP,PERX,3,7.124e-09
MP,PERY,3,7.124e-09
MP,PERZ,3,5.841e-09
TB,ANEL,3
tbdata,1,1.32e11,7.1e10,7.3e10,0,0,0
tbdata,7,1.32e11,7.3e10,0,0,0
tbdata,12,11.5E10,0,0,0
tbdata,16,3.06E10,0,0
tbdata,19,2.56E10,0
tbdata,21,2.56E10
TB,PIEZ,3
tbdata,3,-4.1
tbdata,6,-4.1
tbdata,9,14.1
tbdata,14,10.5
tbdata,16,10.5
MP,DENS,4,7500 !-
MP,PERX,4,7.124e-09
MP,PERY,4,7.124e-09
MP,PERZ,4,5.841e-09
TB,ANEL,4
tbdata,19,2.56E10,0
tbdata,21,2.56E10
TB,PIEZ,4
tbdata,3,4.1
tbdata,6,4.1
tbdata,9,-14.1
tbdata,14,-10.5
tbdata,16,-10.5
BLOCK,0,h1,-b1,b1,-l1,l1,
BLOCK,-h2,0,-b2,b2,-l2,l2,
VGEN,2,2, , , , ,32e-3, ,1
VGEN,2,2, , , , ,-32e-3, ,1
vsel,all
vglue,all
NUMCMP,all
TYPE, 2
MAT, 2
REAL,
ESYS, 0
SECNUM,
ESIZE,0.003,0,
MSHAPE,0,3D
MSHKEY,1
VSEL, , , ,1,2
VMESH,all
TYPE, 2
MAT, 3
REAL,
ESYS, 0
SECNUM,
ESIZE,0.004,0,
MSHAPE,0,3D
MSHKEY,1
VSEL, , , , 3
VMESH,all
TYPE, 1
MAT, 1
REAL,
ESYS, 0
SECNUM,
ESIZE,0.015,0,
SMRT,8
MSHAPE,1,3D
MSHKEY,0
VSEL, , , , 4
VMESH,all
ASEL,S,,,18
NSLA,S,1
cp,18,volt,all
allsel,all
ASEL,S,,,19
NSLA,S,1
cp,19,volt,all
allsel,all
ASEL,S,,,6
NSLA,S,1
cp,6,volt,all
allsel,all
ASEL,S,,,7
NSLA,S,1
cp,7,volt,all
allsel,all
ASEL,S,,,12
NSLA,S,1
cp,12,volt,all
allsel,all
ASEL,S,,,13
NSLA,S,1
cp,13,volt,all
allsel,all
da,18,volt,VOL
da,19,volt,VOL
da,6,volt,VOL
da,7,volt,VOL
da,12,volt,VOL
da,13,volt,VOL
fini
save
!~~~~~~~~~~~~~~~~~~~~~~~~模态分析
/SOL
ANTYPE,2
MSAVE,0
MODOPT,LANB,20
EQSLV,SPAR
MXPAND,20, , ,0
LUMPM,0
PSTRES,0
MODOPT,LANB,20,0,0, ,OFF
SOLVE
FINISH |
